Thanks Carl. I have completed all of the changes, and fixed the hole in the fuse bottom. New throttle servo, new throttle arm configuration, new manual choke config. These changes added room at the carb to make no interference between them. Minor rework of the throttle pushrod, and minor changes to the fueling and overflow lines. No servo extension needed as the throttle servo is close enough. The last thing will be the throttle curve entered on the trans, but I will not make an rx change until another test flight before Sending it back to Spektrum. I am just waiting for Sierra to remill the main nose gear strut and return it.
Then it is test time.
