Thanks. Andy took it.
Stuff:
Service tray.
Put some light plastic over the pull/pull cables for the rudder as there is about 2' of wires/air lines between the wing and fuse that lay in that area when I put the wing on the fuse.
Magnets added to the hatch door.
Darrell's tail gear is mounted on a flat ply in front of the gear door.
The original sheeted piece was aluminum covered and screwed in place.
Same with tail gear doors: original pieces used for the doors.
Dry fit with dubro's heavy duty nylon hinges.
Inner doors painted moss green and aluminum on the outside surface.
Got a bag of springs from the shop and picked two that seemed right for the job. Used dubro small control horns to secure the springs. The longer spring was cut twice, each time about 3/4" off, to get the proper tension to close the doors. The near one 'pops' the doors open and the gear pulls down on the back one to close the doors.
Put a piece of aluminum tape over the sullivan yellow nylon rod used to guide the pull/pull cables.
