If any Futaba reps are monitoring this, the manual calls the 2mm screw by the trigger two different things. On page 15 it's called the Trigger Slide Adjusting Screw. On page 22 it's called the Trigger Slide Mount and the instructions reference a separate Trigger Slide Adjusting Screw that is a different size (2.5mm vs 2mm).
