RCU Forums - View Single Post - Pt22...
Thread: Pt22...
Old 09-08-2019 | 03:05 PM
nonefor2
Default Pt22...
BNIF Seagull PT22..90" wingspan..35cc BNIB...
Seagull Models, Ryan PT-22 Recruit, 30-45cc (ARF) 90" wingspan
Specifications:
  • Wingspan: 90.0 in (228.6 cm)
  • Wing area: 1218.3 sq.in (78.6 sq.dm)
  • Approximate flying weight: 15.4 - 16.8 lbs (7.0 - 7.6 kg)
  • Length: 65.2 in (165.5 cm)
  • Recommended engine size: 30cc - 45cc (electric conversion included)
  • Radio system required: 5 channels with 7 servos.
  • Flying skill level: intermediate / advanced.
Features:
High quality balsa and balsa plywood offer lightweight, state-of-the-art construction
Accurate scale outline and appearance, including airoiled tail surfaces
Highly detailed cockpit
High-quality pre-painted fiberglass cowl
High quality oracover covering is factory applied by skilled craftsman
Numerous scale details include scale wings struts and flying wires, markings, rib tapes, rib screws, inspection covers, drain holes, and scale spinner.
Complete details to build scale main and tailwheel gear and details for bent wire gear as well. Details of all flying wire barackets.
Details for the construction of the scale 5 -cylinder engine cylinders are included.
Working drop-hinge flaps add realistic looks and help to slow down landing speed
Plug in 2 piece wing makes transportation easier
Excellent performance and stability
nonefor2 is offline
