Originally Posted by
Snoopy47
... .40-.60 size glow engine ...
I added that quote to my earlier post to clarify what I was referring to with regard to ic-engine↔e-motor equivalencies being too restrictive.
jollyroger
Lucien does all the testing himself, he knows his business, you can take his motor-prop numbers to the bank
And there are also (
garbage in, garbage out)
e-flight calculators (compilation) - RCG
E.g. eCalc, DriveCalc, ScorpionCalc c.s., MotoCalc.
scirocco
Plane type and mass are leading when selecting power (in watt). Hence these rules of thumb for electric power:
Magic numbers for e-flight - WFF
Note that K
v (in rpm/volt) says absolutely nothing about motor max.power, max.current, torque, efficiency.
K
v only depends on desired rpm and battery voltage. It does effect current and power
drawn greatly though, both are proportional to K
v cubed
More
Prettig weekend
Ron
• Without a watt-meter you are in the dark ... until something starts to glow •
• e-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
