RCU Forums - View Single Post - Problem with Cortex Pro Setup
Old 09-14-2019 | 04:07 PM
ECalderon's Avatar
ECalderon
Default Problem with Cortex Pro Setup
Hi guys
Hope someone can help me.
I have a Carf Viper with JR 28X on Xbus that has dozens of flights. For the gear I have a Jet Tronic 2 way valve.
I installed the Cortex Pro Gyro using the 2 Serial Input and Output. Did the learning signal procedure, then teached the ail-elev-rudd, every thing ok till now.
The problem is that with the transmitter on, and the gear switch in the down position, when I turn on the receivers, inmediatly the gear goes up, even before the gyro has innitialized. I cycle the TX gear switch, the gear comes down and everything is ok again.
Its as if on power up, when the gyro is between the Rxs and the powerbox, a signal is sent to the gear valve, that makes the gear go up, even if the switch in the TX is in the down position. Cycling the gear switch everything is normal again.
Any body know how can I fix this problem? Have tried several things, but nothing seems to work.
Thanks in advance
Regards
Eduardo
