RCU Forums - View Single Post - Problem with Cortex Pro Setup
Old 09-15-2019 | 01:59 AM
F1 Rocket
This can happen on some valves and servos. It’s caused by a slight delay between when the device is powered on and when the control signal arrives. Try redoing the connections on the valve so that the down line is on the what is now the “ up” side. This will keep the gear down when the valve cycles.
