RCU Forums - View Single Post - Problem with Cortex Pro Setup
Old 09-15-2019 | 04:14 AM
Len Todd
Did you try rebinding the Rxers to the Txer with the gear switch in the down position? You did not mention which PBox you have. Maybe the PBox's failsafe is set at the gear up setting.
Later/more complex versions of PBox have their own failsafe settings.
Once PBox programming is figured out, the internal PBox gyro programming is easy.
