The RCV has been reinstalled in the model and a shake-down test with the engine and airframe was conducted. Found a few items that needed attention including a couple of loose cockpit pieces and some engine problems because of a new carb and intake manifold. Did another run today after some work on the carb and the engine is running better but not quite there yet. With any luck, the engine will be running well tomorrow. This photo was before the first test run.
