RE: Corsair.....H-9 or KMP?
I disagee with you Andrew on the color match of your corsair. My wing center section was not even close to the outer wing panels on my corsair. That is why I went to the trouble of repainting the whole plane. I am still troubled about having to tear apart the gear to get it to extend correctly. Even though you mentioned how someone took apart the gear and replaced the grease, I don't feel that I should be responsible to correct the manufactures defect. If I had some clear instructions on how to do this I would. Till then the corsair will sit in the hanger till I come up with some other soloution, such as a different manufacture's gear.
I did mention to you and had faxed you a picture of my fiberglass center section that had dimpled do to the extreme heat here in Las Vegas and it hadn't even been out in the sun yet. It was still in the box in my garage which does get hot in the summer. I do appreciate your concern about your product and I thank you for answering my questions in a timely manner, however I do think you retracts need some attention and I don't think I or any other consumer should be responsible to fix the problem. I would think you would be willing to have us return the gear for a new one when the problem is corrected. Until then, I will hold off buying any more of your product.
Thak you
Greg
Hellcat 716
