Engine Test Stand PSP
Height adjustable, 360 degrees rotating fuel tank mount.
The best way to break in an aircraft motor/engine. RC Engine Test Stand, Engine Break in Stand. THE BEST PERIOD!!! Machined from 6061 aircraft aluminum with S.S. components. ANODIZED BLACK and GOLD. The PSPMFG Engine Test Stand, is the most versatile and safe stand on the market. PSPMFG Engine Test Stands will accept a very wide range of engines, from the small .10 size, to the Super-Tigre 4500, AND with the optional Back Mount Adaptor the GIGANTIC twin 150cc gas burner.Included is a deluxe cushion grip handled balldriver that fits all bolts, smooth operating throttle lever control with cable & throttle arm connector, and fastening hardware.The only engine stand designed with one wrench adjustments.Watch out for those cheap copies and imitations-INSIST on PSPMFG-THE BEST!
