RCU Forums - View Single Post - Problem with Cortex Pro Setup
Old 09-22-2019 | 09:09 AM
ECalderon's Avatar
ECalderon
Tried the learning process with the gear without hold in Didn’t work
To fix it I finally did what F1 Rocket suggested, swaped the air tubing in the valve and reversed the gear channel.
Now when I power on the airplane, the signal to the gear is down, so everything is ok.
Don’t know why this happened but I was able to fix in mechanically instead of electronically.
Thanks to all that replied
Regards
