Sorry but Monokote color is in the adhesive but Ultracote adhesive is a clear layer separate from the color. A bit of heat from a heat gun will allow you to remove Ultracote with ease. Some of the adhesive will remain on the wood but it can be easily removed with acetone, MEK or trim solvent and a rag or paper towel. Sand and recover. Done this many times!!
