Originally Posted by
Agrav8ed
I question for the T-1 veterans. I am in the process of building my T-1 and need to mount the Kevlar fuel tank. I would assume that the goal is to get the tank the furthest back and as close as possible to the turbine and wing tube as possible. Therefore, the smallest cg change possible as the tank empties. Is this the case?
Tone
Yes, I mounted the pipe first then the motor.....then the tank very closed to the starter....work fine as well
