RCU Forums - View Single Post - Types of glue??
Thread: Types of glue??
Old 10-04-2019 | 09:38 AM
tedsander
I use all three. The key to CA's is to have a really tight wood to wood joint. It is terrible at gap filling. It does, however, then provide as good a joint as the others. As long as the wood breaks before any of the glues, you're as strong as it needs to be. CA and epoxy are very hard to sand, Titebond is far preferable in those applications.
So:
Rapid assembly, for internal structures that fit well together: CA
Joints that have some gaps and/or you want a fillet on the outside to beef up the joint (firewalls, wing roots, etc.): Epoxy
External surfaces that will be sanded (wing sheeting edge joined, Fuse sides, etc.): Titebond.
Gorilla Glue: I mostly avoid, due to the foaming characteristic, but there sometimes are applications it can be useful for.
Many years ago I went on a Sig factory tour. Yep, "Sigbond" was just big vats of Titebond put into small bottles.....
