BTW - get a box of baking soda. You can use it as filler in instances where you want to use CA for speed, but have a slight gap. It can foam up a bit, and will be rock hard, so avoid for anything that you may be sanding later. Yes, I have even frequently used it, with thin CA, to fill holes I've drilled in the firewall that need to be relocated.
