This Radio is New , FREE Shipping USA
For more info send a PM or mail to
[email protected]
throwing in a free new futaba external voltage input cable
16SZ Transmitter - 16-Channel Digital Proportional RC System
2-Stick, 16-Channel, FASSTest 2.4 GHz System (01004355-3) (01004356-3)
FEATURES
FASSTEST SYSTEM:
The 16SZ transmitter has adopted the bidirectional communication system "FASSTest". Data from the receiver can be checked in your transmitter. FASSTest is a maximum 16 channels 2.4 GHz dedicated system.
COLOR TOUCH SCREEN LCD:
T16SZ has an HVGA 4.3 inch, full-color backlit LCD touch screen. The screen is transflective which enables both indoor and outdoor visibility.
S.BUS2 SYSTEM:
By using the S.Bus2 system multiple servos, gyros and telemetry sensors are easily installed with a minimum amount of cables.
MODEL TYPES:
Multicopter. 8 swash types are available for helicopters. 7 types of main wings and 3 types of tail wings are available for airplanes and gliders. Functions and mixing functions necessary for each model type are set in advance at the factory.
NIMH BATTERY:
The 16SZ is operated by a 6.0 V/1,800 mAh NiMH battery.
SD CARD (SECURE DIGITAL MEMORY CARD) *NOT INCLUDED:
Model data can be saved to an SD card (SD: 32MB - 2GB, SDHC: 4GB-32GB). When T16SZ transmitter software files are released, the software can be updated by using an SD card update.
EDIT BUTTON:
Two edit buttons are provided, and the operating screen can be immediately "Returned" to the HOME screen during operation. Setting operation can be performed easily by combining this button with a touch sensor.
VIBRATION FUNCTION:
Selects a function that alerts the operator to various alarms by vibrating the transmitter in addition to sounding a buzzer.
SPEECH FUNCTION:
A function is equipped which allows the system to provide telemetry data audibly. This function can also be utilized with commercially available earphones.
CONTENTS
YOUR T16SZ INCLUDES THE FOLLOWING COMPONENTS:
-T16SZ Transmitter (Air Version includes ratcheting throttle, Helicopter Version includes smooth throttle)
-R7008SB Receiver
-HT5F1800B NiMH Battery and Charger
-Switch Harness
-Mini Driver
*NOTE: The battery in the T16SZ transmitter does not arrive already attached to the battery connector. Please connect the battery connector before use.
TRANSMITTER SPECS
TRANSMITTER FREQUENCY:
2.4 GHz band
SYSTEM:
FASSTest18CH, FASSTest12CH, FASST MULT, FASST 7CH, T-FHSS, S-FHSS, switchable
POWER SUPPLY:
6.0 V HT5F1800B NiMH battery
FREQUENCY BAND:
2.4 GHz
RF POWER OUTPUT:
100mW EIRP
RECEIVER SPECS
R7008SB
SIZE:
24.9 mm x 47.3 mm x 14.3 mm
0.98 in x 1.86 in x 0.56 in
WEIGHT:
10.9 g
0.38 oz
POWER REQUIREMENTS:
DC 3.7V~7.4V
VOLTAGE RANGE:
DC 3.5V~8.4V
