Originally Posted by
Glowgeek
To check the airbleed location you can use a T-pin through the hole and rotate the throttle barrel.
Can the 182 be mounted slightly lower on the firewall and the cowl tipped downward slightly?
yes as you advance the throttle the air bleed is closed off
