Man......are you kidding me???? That thing will rip!!!! Sand down the lip off of the trailing edges of the ailerons and the fuselage to keep it from climbing at when you are traveling at higher speeds. The lip adds extra lift to keep it in the air longer with the little 380 geared motor. Once that is done....you will be very happy with your bird!!!!! Post your results!!!!!
