T-1
The T-One Sport is one of the hottest mid-size sport jets on the market. With it's sleek design, solid construction, stunning flight characteristics and competitive pricing, you simply can't go wrong.
The T-1 Sport Jet's low speed agility and low wing loading makes for a great first time jet pilot. But don't be fooled, the T-1 can be an extremely aerobatic machine for the advanced pilot; and has the ability to perform maneuvers effortlessly.
The construction is comprised of Airex composite sandwich core, Fiberglass, Carbon Fiber and aircraft plywood. The exterior colors are painted and polished to a beautiful finish. T-1 Trailing link landing gear, wheels and brakes are solid and smooth (Good for grass fields) The disk brakes make for smooth braking power as well. (Installed Light Package Optional)
Specifications:
Wingspan: 1.92m (75.59)
Length: 2.20m (86.61)
Net Weight: 10.5Kg (23-24Lbs)
Power: K80 - K160 turbine
Other Information:
Airex / composite laminate skins
Carbon fiber reinforcements
2 piece fuselage
Removable tail fins. bolts have metal inserts to guide your allen wrench
All removable surfaces held with double aluminum clamps
Kevlar fuel/smoke tank (125oz / 35oz)
Landing gear steering servo mounted on front strut
Extremely lightweight
Large pre-hinged control surfaces with factory installed double control horns
Gear doors
Sturdy aluminum wing spar
Many available paint schemes, with custom schemes available
Extensive hardware included in kit
Removable nose cone
Removable wood / carbon fiber nose structure!
Description:
T-1 Futune Models from Skymaster US
T-1 has two setup Flights
Comes with a Jet Central Cheetah, new
All high end servos Hitec
BVM air system
Powerbox Mercury with built in Gyro
All Batterries
Carbon UAT
Skymaster USA wing bags
Audi scheme
I have $8000 US in this jet
$7200 with Jet Central Cheetah and Mercury Power Box, just add your receiver.
Best Price ever, Firm
$5400 with no Mercury, JC failsafe, wing bag, ( plastic uat. installed)
Rcpete
