Originally Posted by
049flyer
Down thrust can can really improve the flight handling of high wing flat bottom trainer type aircraft. I added what I thought was too much to a Top Flite Schoolmaster which was a small trainer type as I just described. The plane was the best flying of it’s type I had ever flown. It flew inverted as well as upright which is very unusual for that style of plane, furthermore, power changes did not affect pitch trim to a large degree as is normal for trainer type aircraft. It was a refreshingly neutral flying airplane, capable of good speed, sport aerobatics and yet still retained all of the easy slow flying and slow landing traits common to trainers.
absolutely correct. I find that not many guys learn how to completely trim their airplanes. Far too many get caught up on what full scale does. It's easy to look up specs for a full scale P-51 and draw the conclusion that the model should have the same. Very few guys look to see what the model does and come up with a plan to correct poor flight charictaristics. IMO it's a pretty lame excuse claim that you want to flying charictaristics of the full scale airplane as you fight your model around the sky. Especially when the same guy has never flown the full scale counterpart.
