The 200ti is an even firing engine (both pistons reach tdc at the same time). The compression stroke will alternate between cylinders every 360° of crank rotation. The Saito manual parts diagram shows the front cam facing the opposite direction as the rear cam (180° offset).
Cam gear (left/front)
Cam Gear (right/rear)
