Originally Posted by
JayGTee
Can anyone help me here... I have acquired a 200 ti twin, replaced all bearings and some other bits... but have found that the timing, on the rear cylinder didn’t conform to the usual cam lock @ TDC alignment. It clearly is opening the inlet valve as it gets to TDC on compression stroke.
Does anyone have any advice/guidance/instructions etc that will help me set up the timings gears...
Any / all help much appreciated. !
john.
John,the rear cam may have a slash on it like this one, the slash supercedes the dot on the left cams and maybe the rear cams also.
