SBD-1 problem maybe
I have 3 SBD-1 in a small B-17 1 in each wing and one running to the tail. The problem is in the left wing. 3 servos, 2 throttle 1 aileron. I can not adjust the end points or subtrim the aileron. The right wing works fine. The left servo is on channel 6 and moves in the correct direction and can be reversed. I am out of ideas as to the problem. Servos check fine so wonder if there is a problem in the decoder cable. radio is the 14SG. I have other planes on SBus and everything works fine.
