RCU Forums - View Single Post - Vortex F3A build thread
Old 10-23-2019 | 10:43 PM
  #125
Alex Voicu
Originally Posted by GootyS
How does one modify the trailing edge of an airfoil to make it "thicker"?
The trailing edge is 8mm thick at the wing root and 5mm at the tip. If you want to make it thicker, you can simply cut the trailing edge to get the desired thickness, sand it and apply a 2-2.5mm balsa strip.
