RCU Forums - View Single Post - New Features of the HL 6.0 Electronics
Old 10-28-2019 | 06:31 PM
  #40
johnnyjt
Thumbs up
Originally Posted by Crius
Hey Johnny, that's actually a pretty good idea, so when I get home I'll post the entire manual and then everyone will be able to check it out.
That would be Great. It's very easy and "No Blue Wire Button" Turn on Transmitter, while Holding Start Button Switch on the Tank. That's it. The difference between 6.0 and 6.0s is that on the 6.0s when you try Stick 1 Up and G Button you Turn Off both Head and Tail lights. And when trying the Stick 1 Down and G Button you set Stick 1 Forward Up and Backwards Down and Stick 2 Left and Right Turn. The only problem I have for some reason is that Stick 2 Left turns the Tank Right and Right turns the Tank Left. Everything else seems to be working. Also FYI, the pins for Leds on the Right of the Board are the Same Dimensions as on the Raspberry Pi so if you need more jumper... eBay item number: 273964456080
Johnny
