No! Transmitters transmit on either high shift or low shift. Negative Shift For Futaba and Hitec or Positive Shift For Airtronics and JR. A high shift receiver will not work on a low shift transmitter even if it is on the same crystal. You can get some receivers like the Hitec Supreme that will work on either shift by plugging in a jumper wire into the right position. Note however that it will only work on one transmitter at a time.
