RCU Forums - View Single Post - Advice on radio
Thread: Advice on radio
Old 05-06-2002 | 06:53 PM
f2racer
Default Re: Transmitter<>Receiver
Originally posted by Fastsky
No! Transmitters transmit on either high shift or low shift. Negative Shift For Futaba and Hitec or Positive Shift For Airtronics and JR. A high shift receiver will not work on a low shift transmitter even if it is on the same crystal. You can get some receivers like the Hitec Supreme that will work on either shift by plugging in a jumper wire into the right position. Note however that it will only work on one transmitter at a time.
Actually, I think Hitec does have a shift selectable TX, the Prism. The specs say that with its shift selectable option, the 7X is capable of operating almost any 72 MHz FM receiver regardless of what brand it is... Anybody know if this is true?
