1. I don’t have any data to tell but I trust their engine spec, like the idle thrust is minimal, similar to what they say,
3. I am using Mobil jet oil, no abnormally found
3. My UAT is made by Spark, a one piece plastic small tank with metal filtering element hard mounted in the center of the tank. Pretty reliable but I want to get rid of it to save weight
4. I use ball links and balls from my helicopter spare, like JR or Hirobo make
5. I don’t use any voltage regulator on board, just 2 1500 mAH LiPo.
6. I use CA on all hinges except epoxy in flap hinges
7. I use 45mm JP brake wheels, to make it lighter. The catch is to replace the bearings with quality ones. The point , I think is not the wheels, it is the strut spring rate. The later version of M Avanti comes standard with the new version strut which is softer, can absorb shock load during hard landing.
8. I use 40mm JP wheel at the front .
hope this help
