Originally Posted by
Rad_Schuhart
WIth a bit of easy programming (which is selecting a couple of things in the radio menu, no writting codes and needing a degree for that) he will be able to sort the issue soon.
Which I've now easily done in less than 15 minutes. Now even the GBS and combat lights are single touch. Check out the edit to my first post. Programmable radios are indeed superior. For the same cost of less, you get infinitely more out of it, with literally no downsides at all. Thanks for the encouragement. Even happier now. Hope this encourages users here to use programmable radios.
