ORIGINAL: apereira
By offset I mean the ailerons should begin moving after you moved 30% the elevator already, if not the airplane might not go nose up to harrier on some conditions and it is usually at hight angles of attack when the wing rocks, also check the lateral balance, if it is not balanced it will never stop to rock the wings.
I'll need to program that into my 9CAP. There is so much stuff this radio is cable of doing, but I just haven't had the motivation to do it.
