RCU Forums - View Single Post - Tachometer
Thread: Tachometer
Old 11-12-2019 | 06:58 AM
Jesse Open's Avatar
Jesse Open
Talking
Originally Posted by RACE 66
I am stingy on tachs. Now that I've said that, my first tach was a kit built one out of 'old school' ACE radio control, Higginsville, Mo. for 30 bucks and you adjusted the sensitivity by pointing it to a light bulb, remember those or a fluorescent tube and with that it would count the AC cycles of the light and thus you can adjust the tach to 'zero'. Still works ok.
Then I went to a TNC, wanting to buy 1 more time, this was well before the 'mini tachs' you see now. Spent $100 dollars and at the time, besides the 2 and 3 blade choice they normally give you, I was building a P-51 giant scale at the time and was incorporating a 4 bladed prop, in doing so, I asked 'TNC' which was the original person that had designed the tach if he could incorporate an '4 blade option'. He did, with a small micro slide switch that is separate on the side of tach and the option works like a jewel. Bullet proof tach it is. And I really like that you can 'point' the tach a distance away and not be threatened by the whirling prop.
Mike
Yes sir!
That operating distance improvement is great. Can help keep old cow milkers from getting their livelyhood whacked.
The latest is built bomb proof too, with a CNC machined from billet aluminum case.
My first tach was a Heathkit Thumbtack kit from the mid-1970s. Got the Ace Tachmaster much later.
