Hi Guys,
Can anyone suggest their preferred ball link size and clevis upgrades for the control linkage? I use Dubro Clevis's on both ends and I also turn the Flap control horn around for better mechnical advantage!
Any reason I shouldn't use epoxy on all hinges versus CA? Because the hinges are designed to be glued with CA
Does anyone know whether the 55 mm JP Hobby main wheels/brakes fit the existing cutouts without problem when retracted? You should buy the better struts available from
www.Effluxrc.com
Has anyone tried either a 45 or 50 mm JP Hobby nose wheel? Curious if either fit without modifications..
Raz
