Originally Posted by
XchosenlegacyX
I also do not have oscilloscope, but I do get a constant .5v across all data points, but it doesn’t change with any transmitter input, for instance, I get the constant 5v out to the sound card, but the data voltage never changes with any input from the transmitter. Also I don’t get any power change from motor outputs, be it high or low outputs, nothing from them to drive motors with sticks, but right next to it I have my 7+v looking to drive it??
The "reciever" section of the circuitry could be bad. So there should be a single signal from the antenna that is read and then all the controlled outputs are separated from that. If the board has voltages and some clock signals I would suspect the input signal is not being decoded.
