Originally Posted by
F1 Rocket
In the serial in/serial output mode the Cortex Pro (CP) will output all channels via S Bus. You can then use a S Bus hub to connect your servos. The input to the CP must be S Bus. Not S Bus 2.
F1 - Checked the long manual and it work. But the surfaces are backwards. Connected A into regular Sbus, then CP 5 into the Sbus hub. Powered up the Gyro and followed the surface program sequence. All surfaces were programed and switch established. Trying to set surfaces right. Trying the program sequence backwards. I guess the hard part has been taken care off!
