RCU Forums - View Single Post - TF Beechcraft Bonanza F33A Build
Thread
11-17-2019, 01:33 PM
441
VincentJ
Time to join the two halves of the elevators with a
elevator joiner wire and horn
. A 9/64" hole was drilled to accept the wire, then a groove was made so the wire could sit flush in the LE of the elevator.
Later when epoxied in place, the wire will be reinforced with a strip of fiberglass.
With the two halves joined, I will need to cut out F11A to give access for the horn on the elevator joiner wire. I've marked the area.
I will need to further enlarge this opening later as the
rudder torque rod
will also exit in this area. The stabilizer's trailing edge will also need to be notched allowing the horn to pivot freely.
01:11 AM
Reply
Like
VincentJ
View Public Profile
Send a private message to VincentJ
Find More Posts by VincentJ
View iTrader Profile
