Originally Posted by
camss69
I just ordered and received the LG15 to go with my JP gear. You guys are making me nervous now, if my gear don’t come down, it’s gear up across asphalt or in the dirt clods. I have a spare regulator I think I will use just to be safe.
I have 2 of these fine controllers, thinking it was going to solve all my issues....not so much, in my mini JP gear has been solid with that controller but the brakes are still weak...
With T-1...not so lucky...but my last problem was the trunnions and one motor, after 2 almost full seasons....
The thing is if you see something that the plane doesn’t normally do, in my case sometime one gear wouldn’t do all the way up.....I stop flying that plane and took the gear apart once home and discover the trunnions problems.....got some trunnions and discover the motor also need to be replaced again...cut my loses and order the electron set no controller, I will used the LG15...
