Originally Posted by
camss69
I’m putting the electron gear in my T-1, I was thinking about ordering the electron for the mini as well...
If you fly that plane a lot then I say it’s a good plan....sometime over the winter I will take the gear out of the mini and evaluate their condition....will order a set as required I got about 200 flights on that one...tires are worn out completely (all 3).....I have the LG15 in both the T-1 and Mini, all I have to do is take the voltage regulator out.....
The only thing I didn’t check is the bolt pattern.....but I can fixed the hole with wood and hysol and drill the new one....I got 3 set of electron on the way LOL...
