Originally Posted by
bushong572
I have the same problem with the mains after only 20 or so flights. The gear had plenty of clearance in the beginning. Now, the tires are starting to rub in the wheel well because the struts are not extending out 100% after compression. I removed the struts and placed a washer (as a spacer) in the retract unit. That has solved that problem but it now appears I have burned out a motor.
How do I get a replacement?
Pacific Jet has replacement motors.....
