Originally Posted by
extra 300
Truckracer,
Thank you for your input. In fact my DA60 is from early production as I bought it back in 2011 (if I recall well). I will start by checking Fuel tank, then carb and will check ignition/timing as per your suggestion. Will do steps one at a time trying to sort out problem
Thanks again
Regards,
Hello, did you find out what was the problem??
I have 2 DA 60cc engines with the same problem that you have. I did check the ignition, sensor and the carb, everything do look good!! I do own 7 DA engines, and I never had problem with them except for the 60cc only!!
