RCU Forums - View Single Post - Ever hook up your ailerons backwards? Avoid that problem with servo plug labels!
Thread
11-28-2019 | 04:41 PM
1
unclegeorge
My Feedback: (
12
Jan 2003
673
SARASOTA, FL
NEW! Now brighter color coded servo labels make it EZ to see and use. Signal wire arrow indicator so they plug in right the first try and there are enough labels for 6 planes on just one sheet of labels. You should use a new #10 Exacto blade, they are not pre-cut due to cost of production. No trouble for a real modeler. You seen the ad before but never order, once you use them you will wonder why you waited so long!!! My Pay Pal account is
[email protected]
(Color code makes it easy to recognize when setting up your plane at the flying field!)There is enough labels for 6 planes for only $3.00 each + $1.00 S&H. I can mail 3 sheep for the same S&H of $1.00! Keep the label on the servo so you can tell what you used it for in the last plane!
No more using masking tape. label makers or paint to identify "which plug goes where". I have lots of them ready to ship so look at the advantages.
You Jet and Scale guys are going to love these labels!
1. These are printed on self adhesive Avery label material that won't let go until you are ready to peel them off the plug.
2. They are printed with Black ink on Bright Colors using Avery label material so the color are easy to see and read in the darkest places in your model.
3. They are indexed with a arrow so you do not have to worry about plugging them in the wrong way. Labels for Battery, Switch and charger included! You can mark them with a thin line Black Sharpie!
EZ to read through the clear Servo Safety clips as well.
I can ship 3 sheet of labels for the same $1.00 cost!
I do not ship outside the US or other countries. I no longer take Money Orders but will take personal checks! Send a personal check if you do not have a Pay Pal Account! My mailing address : George Jenkins, 2012 Old Arbor Court, Sarasota, Fl. 34232
Like
unclegeorge
View Public Profile
Send a private message to unclegeorge
Find More Posts by unclegeorge
View iTrader Profile
