RCU Forums - View Single Post - BME 50 Ignition Question.
Old 11-06-2003 | 11:33 AM
Antique's Avatar
Antique
Default RE: BME 50 Ignition Question.
Most use a hose clamp around the base of the spark plug..Your setup is better...Makes no difference where you put the wire as long as it's connected to the engine somewhere..If the wire breaks the spark will take the shortest path to ground, through the Hall sensor..It will go bad almost immediately..Looks like the wire is long enough, maybe you could use the hose clamp and then the bolt....
