I have seen and read about similar issues with the DA 60. The problem can be the circuitous route used for the carb pulse through the reed block where a gasket or something else can cause a partial blockage. The way I and others have resolved this issue is to drill a hole in either the engine block or reed block and install a pressure tap and route to the carb for pump pulse as is the case for example with the DA50. Problem solved.
