RCU Forums - View Single Post - new feul, engine stalls
Old 11-06-2003 | 11:52 AM
FLYBOY's Avatar
FLYBOY
Default RE: new feul, engine stalls
Shake the container and hold it up to the light. If there is precip floating in it, it is bad.
Clean out your carb and inlet. May have gotten a spec of dirt in it causing the problem.
Check it with the other fuel and if the problem is still there, change the plug. You may have run it too lean and ruined the plug. I would change it first and try the 15% again.
