Hi All , 65 WS x 56 1/2 length very solid Bones, YS 120F Engine turns over Smoothly but has low compression could possibly be a stuck valve or Piston ring maybe a simple Fix I would think just being honest about the bird , as some of you know these are Great Flyers!! Has all futaba Servos the Turtle Deck is a High Quality vacuum formed plastic it's a wood construction some of the Covering is coming loose either fix it with a iron or recover it's still Flyible like this but you may want to consider a recover down the road, Asking 300.00$thank you for viewing.
