Question for this group:
For those of you using a Powerbox Mercury SRS with iGyro and gear sequencer. Are you using the PB Mercury gear and door sequencer in your T-1 Mini or are you using the JP retract controller to accomplish the door and gear tasks?
I am using the JP controller in my MB-339 and I find configuring and setting it up somewhat tedious. I think the PB Mercury would likely do a better job and would be accomplished easier.
For the iGyro, would it be helpful to start with gyro settings obtained from someone here who is also using a K85 for power, or should I just start from scratch using the Mercury Test Flight assistant?
R
