Len, Thanks for your insights. Valuable for sure. I am using JR XBus-A protocol. I assume the Mercury is installed upstream of the LCG-15. Then patch cords go from the individual retract, brake, and Rudder-B (nose wheel) output ports of the Mercury to the LCG-15? Can you confirm? Are you applying Mercury iGyro gain to the Rudder-B (nose wheel) or are you letting only the LCG-15 control the nose wheel gyro function? Thanks.
R
