RCU Forums - View Single Post - CG On E-Flite Extra 300 1.3m
Old 12-10-2019 | 04:19 AM
ahicks
First, welcome to the forum!
I have no experience with your particular plane, but I feel safe in sharing the fact that once past your maiden, where you CG is at, or needs to be, is up to you and the way the plane flies. Don't worry about where the instructions tell you to put it, that's only a suggestion to get you through a maiden safely. After that, put it where it needs to go to fly right! There are all kinds of tests that can be done in flight to give you some hints at where that might need to be.
