RCU Forums - View Single Post - Safe surfaces to run a tank
Old 12-16-2019 | 08:33 PM
Fsttanks
Originally Posted by Argess
Thank-you both for your replies.
It's a Heng Long 1:16 M4A3 Sherman 3898 with metal tracks. Warnings are fine, but it's nice when you know the "why". I imagine the treads having wider spacing as they go around the front and rear wheels could pick up something solid, and then when the treads close up, the grit keeps them forces apart and they break apart. Wear from grit is more easily understood and avoided.
The M4 is a pretty durable HL tank so you should not have any issues as long as you take it easy at first and build up to harder terrain. It will not take long for you to learn the limits of the tank and you will have a fun in the process.
Don’t forget to post some photos of the fun.
