Newbie xk k100
Hello,
I tried searching for some help first and couldn't find what I'm looking for. I have had a few rc copters. I started with the Syma double rotor. Went to the v911. After mastering both I asked Santa and got the xk k100 6ch cp copter. It works and flies pretty good. However while in the basic mode I have to throttle up to 80% to get it off the ground. Same with cp mode. It doesn't want to go up quickly but will drop like a stone when told to. Is this normal? All the other things I've flown will go up way faster than this one. It has lots of power and is very responsive. It's just the lift that doesn't seem to work well. Any advice is appreciated. Thank you in advance. Also I tried messing with the throttle curves and no matter what I change it to the lift just isn't there.
